RE: New TF Sea Fury!!
Check your engine thrust. Mine flew great then after a flap problem causing a slow roll into the ground, I had to rebuild the firewall. It began to give me fits on takeoffs and landings. I re-checked the down thrust and added a couple degrees back in and all is well again.
