RCU Forums - View Single Post - Fuel starvation in a dive?
Old 06-28-2006 | 05:57 AM
bkdavy's Avatar
bkdavy
Default RE: Fuel starvation in a dive?
I have had problems on some planes with short fuel lines in a dive. As you surmise, the fuel in the line is the primary source. Typically in a dive, you reduce throttle, which obviously reduces fuel demand. Another trick I've used is to put a loop in the fuel line between the tank and the carb. This provides an additional fuel reservoir. A large fuel filter can also help. In the extreme, a header tank can also help.
Most dives don't last long enough to require a lot of fuel.
Brad
