? about Somethin Extra
The 46 will pull the plane around,but not unlimited vertical,the Saito should give unlimited vertical,mine at the present time has OS 70 FS,has limited pull out in hover,plan on changing to OS 90 FS when I finish some other building projects. To get prop clearence I use taller wheels,if that fails I change to taller landing gear and or wheels.
