RCU Forums - View Single Post - 2X4 GASSER SPAD
Old 06-28-2006 | 12:45 PM
ChrisSpad
Default RE: 2X4 GASSER SPAD
the same nut that holds the prop on holds the flywheel in place - this is a fairly typical setup for a long shaft engine - instead of using the steel spacer and washer, most people use a piece of 1" aluminum round stock or similar, drilled to slide over the shaft.
