RCU Forums - View Single Post - 9303 or 10X for Jet
Old 06-28-2006 | 06:30 PM
KC36330
Default RE: 9303 or 10X for Jet
ORIGINAL: rcjet lynch
It will buddy box just fine but you can not transfer from one to the other and yes to the independent trims.
i use the 10X heli version for all my planks because they are out numbered 3 to 7 with heli's and it Does allow transfer of models between it and another 10X (use code 86 Data Transfer) but does Not allow trainer functions, i wouldn't think the aero version would disallow the transfer function and only the Aero version allows buddy boxing (pilot link).
kc
Edit the 10X aero features:
System Features
- Tilting Antenna Base
- Touch Panel Display
- Digital Aileron Trim
- Digital Rudder Trim
- Digital Elevator Trim
- Mechanical Throttle Trim
- Aileron/Elevator Stick
- Throttle/Rudder Stick
- Flap Lever
- Elevator D/R
- Aileron D/R
- Rudder D/R
- Snap Roll Button/Pilot Link
- Mix Switch
- Flap Switch
- Throttle Channel
- Aileron Channel
- Elevator Channel
- Rudder Channel
- Gear Channel
- Auxiliary 1 Channel
Program Features
- Reversing Switches
- Travel Adjust/ATV/ End Point Adjust
- Dual Rate/Exponential Adjustments
- Trace Rate
- Sub-Trim Adjustment
- Function Select
- Programmable Throttle Curve
- Wing Type Selection
- Servo Speed
- Data Reset
- Snap Roll
- Gyro Gain Sensitivity System
- Standard Programmable Mixing
- Multi-Point Programmable Mixing
- Aileron-to-Rudder Mixing
- Elevator-to-Flap Mixing
- Rudder-to-Aileron/Elevator Mixing
- Flap System
- Servo Monitor
- Fail-Safe/Hold
- Pilot Link
- Model Name Input
- Trim Offset Adjustment
- Model Selection
- Modulation Selection (SPCM, ZPCM, PPM)
- Data Transfer
- Timer
- Keyboard Lock
- Auxiliary 2 Channel
- Auxiliary 3 Channel
- Auxiliary 4 Channel
- Auxiliary 5 Channel
