RE: 9303 or 10X for Jet
I'm using a 9303 for a C Bobcat. Great radio. However, I was unable to use the published BVM 10x setup instructions for crow settings. I had to do it myself with some help from the JR guys. Turned out to be straightforward and pretty easily done. So, if you want to be able to quickly setup a plane using known 10x settings and you need the extra channel, then go with the 10x. If you are willing to work through the 9303 setup process (which is pretty easy) and you don't need the extra channel, then the 9303 works great for several hundred bucks less.
Bob R.
