RCU Forums - View Single Post - TL-01 Is it driftable???
Old 06-29-2006 | 06:19 PM
Yomillio's Avatar
Yomillio
Default RE: TL-01 Is it driftable???
I got my ABS tires from eBay because I was too lazy to go to the hardware store, get 2" ABS, and cut it to the right size. Any motor above 17 turns (winds) will work fine, but somewhere in the low-20's is best. Your stock ESC is fine as long as it can handle the amount of turns your new motor will have. Make sure you read the stickied topic at the top of the page, it should give you a lot of help getting into drifting.
