ORIGINAL: mirwin
Here's an alternative that I've used with great success on my O.S. and Magnum 4-strokes.
Purchase a small can of Rustoleum aluminum brush-on paint (it's even aluminum colored). After cleaning the threads on all the mating surfaces, brush on a coat of the paint on each surface. Let dry. Assemble. The heat of the exhaust system combined with aluminum in the paint creates a good, tight bond.
I agree with MinnFlyer too; make sure your prop is balanced perfectly. But sometimes you just get an engine that shakes. In that case, I fasten the muffler to the fuse to (1) minimize muffler movement and (2) avoid losing it if it comes all the way off.
Mike
Good tip. I'm going to try the Rustoleum on my next shaker.
