RCU Forums - View Single Post - How do you set up kill switch for EI engine?
Old 06-29-2006 | 10:42 PM
Magna
Default How do you set up kill switch for EI engine?
Hi all
I'm familiar with the Magneto engine kill switch setup (G26) but not on the EI type.
Though I can off the power supply switch to the ignition unit, what about the remote kill as Servo actuated?
Do you create a circuit on the grounding wire? With the GP kill switch unit, how is the setup go? Between the black color ground wire?
My Zenoah g20 EI does not explain such!
Thanks!
