RCU Forums - View Single Post - How do you set up kill switch for EI engine?
Old 06-30-2006 | 09:01 AM
tkg
Default RE: How do you set up kill switch for EI engine?
Simple= use a servo operated switch with a push rod to shut off the power,
Also simple= use a servo to close choke.. If you fly pcm use failsafe presets to do either one.
Best=use optical switch
