RCU Forums - View Single Post - field box plans?
Old 06-30-2006 | 01:13 PM
Fastsky's Avatar
Fastsky
Default RE: field box plans?
Looks good. Just a suggestion, if you have a 12 volt battery inside on one side of the box the inside and the power panel mounted on the other side through the side so that you can plug in your starter and glow driver with out having to have the lid open then the set up will work well for you. [8D]
