RE: What is best 'House Paint' to use? And, anything special used for Airbrush thinning?
gary your stang looks great. what kit did you use? floetrol retards drying time to allow latex to flow out and give a smoother finish ,its mostly used for trim paint. window washer fluid seems to work well it has a combonation of a cleaner and alcohol.
here's another tip if you want to get your latex to set quick mix a small amt.of denatured alcohol 10% into the paint then thin with water for spraying, when you spray it evaporates and sets the paint faster so the paint doesn't run and drys faster without the soap that WWF has.
