RCU Forums - View Single Post - Moving the workshop!!!
Old 07-01-2006 | 04:29 AM
Kevin Greene's Avatar
Kevin Greene
My Feedback: (85)
Default RE: Moving the workshop!!!
My new workshop will be inside of the house in a converted storage area---Not as large as I would have liked at 10X15 feet but it sure beats the cramped corner of the garage I once had... [:@]--The main thing is that it is HEATED and AIR-CONDITIONED!!!![sm=thumbup.gif]---It can get to around zero here in a bad winter and into the low 100's on a hot summer---High tomorrow is 96 degrees with a TON of humidity...The air-conditioning will be VERY welcome...The plan is to be in the workshop---I mean home---In the early fall...
The new shop will have plenty of lighting, cabinetry, and a 10' long Formica topped workbench with cabinets underneath. In the center of the workbench between the two lower cabinets there will be a separate rolling cabinet that will pull out from underneath the bench so that I can get to all sides of a model and still have a flat surface to work on in the center of the shop...I'll post some pics when done...
Kevin
