RE: WACO YMF
common mistake of using the flat section of a flat bottom airfoil such as a clark y etc, as 0 degree incidence,as the true incidence runs from the center of the le to the center of the trailing edge and is usually 2-3 degrees positive if the flat portion is at 0
