RE: Excelleron 90
Thanks for the info, especially on the CG. On the aileron deflection, the plane made three axial rolls in less than 5 seconds with 1/4" (approx. 6mm) deflection. However, it was a little sluggish in doing snaps with that limited amount of deflection. It is the first plane that I had that I should be able to do an 8-point roll reasonably well. So far, the only complaint I have is about its long, spinging landing gear. Since I'm not going to install a fixed gear in it, maybe the only solution is to buy an Excelleron.
Allan
