My Blade is lookin' good
Carbon Fibers might not be the best choice if you have blade stikes, but man do they look cool. Anywho, I'm back up and running. I didn't realize how soft the metal is that they use for the shaft. Great engineering on their part for selling future parts. I had to use a dremel to shave the bent out metal around the shear pin because the bearings and the brass ball would not slip by. even the shear pin was alittle bent. I also put double heat sinks on the main and tail motors to help cool them down in this Michigan heat and humidity. I hope I can keep it from taking another dirt nap
