Pilatus PC-9, VMAR or Seagull?
DFMan
By now you must be tearing the box open, but don't rush the assembly.
I'm sure you'll be surprised the way they don't bounce around in a breeze like the flat bottom wing trainers, just don't let it get too far away, as somebody earlier mentioned, the wing colours are identical top & bottom.
Also don't believe any crap about them dropping a wing if you hold it off a little for a smooth touchdown on the main gear.
Col Taylor still has them at $229 with the 80" version at $529 but at least you're doing the right thing and supporting your local shop.
I just know you'll really enjoy it.
Marshy, I'd appreciate it if you could measure the diameter of the cowl (inside the lip) of the Corsair as I'm wondering if the Saito 3 cylinder 90R would fit in ?
