The Hauler Mk1
This is the modified Hauler It started out as a Viper Ailerons are controlled by two HS85's mounted under the wing and covered with a streamilined pod This will give solid postive control instead of soft torque rod response. The elevator is mounted in the wing where the aileron would be and the pushrod goes straight back again giving postive control Right now it weighs 3lbs 6oz but we will put insome big batteries and get the weight up to 3 1/2 It is not a heavy Hauler Two flights were made sat but the wing has a warp and needs to be straightened
