RCU Forums - View Single Post - BME 50 Wildhare Ultimate Build Thread
Old 07-02-2006 | 10:58 PM
  #69
tomriddle's Avatar
tomriddle
Default RE: BME 50 Wildhare Ultimate Build Thread
Okay, just when you all thought it was safe, I get the 4th of July weekend off!! Time to play...red airwild arms fit perfectly on the HiTechs, so they are on. Sealed the hinges. Pinned the firewall. Installed the fuel tank. Re-mounted the engine and started working the connections to the carb. Mounted the ignition module and the switch. Used some Ernst charge jacks for the connection point for the upper aileron servo leads where they come into the fuse. Mounted the choke and throttle servos. Good day!
ID:	486097   Click image for larger version
ID:	486098   Click image for larger version
