RE: The Evader Coalition - T.E.C.
Hi thank you for the compliment, In my ST the up grade i did in the tranny was 1 i got the metal idler from the nitro evader and installed the nylon B2 diff gear. i also used the b2 diff ring and used the stelth diff greese it supposed to be really good. i kept the same steel balls in it they work fine for me. in the future though i might change the diff to the metal one i have if i blow out the one i have now, but my tranny is holding up really nice and its really smooth and im running the ss+ 5800. IN my other vader the buggy, i used the duratrax diff rebuilt kit, even though i didnt need to and i also installed a nylon b2 diff gear using the same stealth greese for the diff. that was pretty much it and the buggy is alot smoother also. My next order for stuff im going to order a metal idler for the buggy and more nylon b2 diff gears and more greese. Im keeping the metal diff gear like i said if i blow the nylon gear but so far its holding up pretty good.
