RCU Forums - View Single Post - Phoenix Models Giles 202 CG
Old 07-03-2006 | 04:12 AM
jernejk
Default RE: Phoenix Models Giles 202 CG
Just for the record:
I did the following modifications to the plane:
- cut out the pilot (and painted the canopy black)
- added 1cm plywood to position the engine further from the firewall
- reinforced the "weak spot" with 110g fiberglass and epoxy (under the canopy)
The CG is now just where it has to be :-) The plane has flown once to date. It is slightly underpowered with MVVS .45 (needs long concrete runway), but I can't really say until I do some more flights.
Pictures can be found here: http://forum.modelarji.com/viewtopic...r=asc&start=20 (don't mind the language)
Rgs
Jernej
