RCU Forums - View Single Post - STALLED? OR RADIO MALFUNCTION!
Old 07-03-2006 | 09:07 AM
cjposada's Avatar
cjposada
Default RE: STALLED? OR RADIO MALFUNCTION!
When I tried to pull out of the halve loop it did not look to be going to fast. Better said kind of slow but remember that this model is not flat bottom wing, it is semi and the dihedral is minimum.
After I am done with landing practice would you recomend to go with a bigger prop? Remember I was flying with a TT .46 and a 10X6 prop to better slow it down . Maby a 11X6 would be better for attempting some tricks? Is it correct to assume that a bigger diameter and lower pitch prop gives the model better climbing capabilities?
