RE: Middle Engine?
I saw a similar system on a scale pilatus porter, a high wing beast with a long thin nose. The shaft was much shorter than yours and only supported at the prop end, seemed to work fine. Cooling may be an issue for you, the porter had an intake directly in front of the engine & an air duct about 200mm long. - John.
