RE: Platt Spitfire build
got a little more work done. The wing has all the detail done pannel lines ,rivits,used plu
mmers tape to simulate pannels and accsess pannels. Fusalage is primmered, got Griffen motor shroud done. Horizontal pannel lines done . now adding vertical pannel lines. I just put masking tape where I want the lines. Then use auto primer sprayed along the tape, several coats to make a good pannel line. I use an automotive touch up gun. you don't waste much paint and not much overspray.
I really haven't decided which plane I am going to do. Waiting on some info. Notice I left it a full wing. I still may make it a clipped wing. It will be either a MKX11 or MKX1V.
I also used primer on the ail and tail feathers to simulate scale detail
