RCU Forums - View Single Post - Using a Pmix to implement throttle cut -9C
Old 07-03-2006 | 08:27 PM
henry.horrocks
Default Using a Pmix to implement throttle cut -9C
Hello,
I'm flying an Ultra Stick with four servos on the wing - two for flaps and two for ailerons. In order to set up this configuration it's easiest to use the GLID-2-FLAP choice in the 9C. (you _can_ do it with an ACRO program, but it's quite complicated that way).
One drawback however is there is no throttle cut available in the GLID-2-FLAP, so I'd like to use a pmix to set this up.
Basically I want to use the spring loaded switch to move the throttle (called AIRBRK on GLID-2_FLAP) to the fully cut off position - just the way it's done w/ airplane models.
So I'm thinking a PMIX. Would I use ARBRK as both master and slave? Do I need an offest?
If you could explain how to to this step-by-step I'd greatly appreciate it. BTW if it matters, its a 9C Heli version.
Thank you
Henry
