RCU Forums - View Single Post - Any help with Tower .46?
Old 07-03-2006 | 09:13 PM
wcmorrison
Default RE: Any help with Tower .46?
Sounds like an air leak. Loosen the carb and press down real hard on the carb while tightening back up. Make sure the back plate bolts are tight. Make sure the head bolts are tight. Once you get all the possible air leaks taken care of, it will be less tempermental.
Cheers,
Chip
