RCU Forums - View Single Post - jr x3810 help
Old 07-03-2006 | 10:35 PM
Ed_Moorman's Avatar
Ed_Moorman
Default RE: jr x3810 help
The 8103, 3810 in Europe, had 6 mixes. 1 & 2 are multi-point mixes without trim. 3 & 4 are the plain vanilla mixes. 5 & 6 are trinm mixes. If you need the master trim switch to trim both channels, you'll need to use mix 5 or 6.
As has been mentioned, if you are using 2 channels for ailerons, this is built in as a Flaperon Wing Type in the Set-up menu. Plug the right aileron servo into channel 2 and the left aileron servo into channel 6. This will give you ailerons and flaps with trim on both surfaces.
