RCU Forums - View Single Post - Fuel Proofing Goof
Old 07-04-2006 | 01:03 AM
RC Bird
Default RE: Fuel Proofing Goof
Hi All,
Thanks so much for the suggestions. I followed Ken's advice and removed the epoxy with rubbing alcohol and water. It worked like a charm and I was able to reapply epoxy with the correct hardening mix. HuskerBoy, I took your advice and applied heat to get all of the cracks. I'm really happy with the results.
Everything looks great. The fuelproofing is done and I've mounted the engine. I'm now hooking up the servos.
Thanks again for your expert advice.
