RCU Forums - View Single Post - typhoon transmitter
Old 07-04-2006 | 01:39 AM
Get Real's Avatar
Get Real
Default RE: typhoon transmitter
ORIGINAL: traxxboy
Hello I was wandering if the pz typhoon's transmiter is 5 channels. I see an extra swithc at top. There is the dual control rate switch and another switch.
i own a typhoon.. yes it does have a 5th channel built in and its activated with the high rate switch on upper right of radio when jumper on reciever is removed. when the jumper is in reciever it enables dual aileron servos without a y harness. its stated in the manual. and can be downloaded in pdf format here under support http://www.parkzone.com/Products/Def...ProdID=PKZ4100
