RCU Forums - View Single Post - Corsair setup
Old 07-04-2006 | 02:12 AM
Heavy1000
Default RE: Corsair setup
hellcat is right, i dont think you will get any incidence info in any ARTF build manual, just make the wing tip to stab tip distances 0 and the stab tip to ground (flat surface) 0 and fin tip to stab tip 0, you will be fine, the following link has some usefull info on cg for this plane, there is a lot of waffle in it, but look through and see. i had the phoenix corsair, flew beautifully till i had dumb fingers, be very very carfull on the elevator throws, on mine it was incredibly sensitive and the first flight almost gave me a heart attack.
hope this helps:
http://www.rcuniverse.com/forum/m_644582/printable.htm
