RE: Phantoms Phorever!
Jason,
I personally like to run my REGULAR rx antenna on the outside of the Jet ( I feel much safer ). I have 2 F-4's and one of them is powered by a Titan and the other by AMT. I also run 2 heavy duty JR switches with the charge jack for convenience. I run a pair of 6V. 2000mah Nicads and charge every three flights. Each battery and switch is plugged into a separate channel of the rx just in case one of the two fails. I try to keep everything in the nose of the bird also for convenience like fuel filler, propane filler,switches, air, air valves and ECU.
Here are some shots, the first picture shows you how I run my antenna.
