RCU Forums - View Single Post - Sheeting foam cores
Old 12-29-2002 | 06:57 PM
GW-inactive
Default Sheeting foam cores
Elmers white glue for the wing joints. Used it for years.
Probond Ploy glue for the skinning. I have some stuff on my webpage about the skinning fo my Ricochet wing.
Using probond, if you just tape the seams together with a seamless joint there is really no reason to glue the sheets together. The probond will handle that for you. Works fine.
