Sheeting foam cores
I use thick CA to glue the skins together,then Z-poxy finishing resin,polyurethane glue,or slow epoxy in that order is my favorite glue,white or yellow glue works also.What ever glue you choose,use very little,after smearing the glue on the foam I then take a putty knife and remove the excess
