RCU Forums - View Single Post - New Video: HOW-To..3D maneuvers
Old 07-04-2006 | 12:55 PM
MikeEast's Avatar
MikeEast
Default RE: HOW-To..3D maneuvers
Upright Flat Spin
Same setup as above.
1. Chop the throttle and ease in high rate elevator until the plane stalls.
2, Input full up elevator, full left aileron and full left rudder and the plane will start to spin.
3. As the plane starts to spins hold full elevator and rudder and let the ailerons come back to neutral.
4. Adjust the throttle to keep the nose level. You may have to adjust the elevator a little, but if you play the throttle right and dont add too much, you should be able to hold full up.
The plane will spin either but to the left it works better because you are working with instead of against other forces.
Variation
Let out of the rudder slowly to decrease the rate of spin. The spin will slow and eventually open up into a flat spin/turn.
To transition from upright spin to inverted spin simply move the sticks from one spin to the other, Just make sure that you input to keep the rotation of the spin the same. IE if you are spinning inverted clockwise make sure that you move into an upright spin that will continue clockwise. This normally means siomply crossing over with the ailerons and applying full up elevator, or vice versa depending on what you are doing.
Im am including a second video of what the transitions look like. [8D]
[link=http://www.youtube.com/watch?v=EWOFavAWIZA]Upright Flat Spin Video[/link]
[link=http://www.youtube.com/watch?v=gpNdHhLUH4g]Inverted to Upright Spin Transitions[/link]
