Originally posted by ml3456
Vince and others,
Thanks for your advice. I am doing my first sheeting, and edge gluing seems like a real pain to get correct.
If this glue leaks a little bit on the tape seam does it bond th tape or tape adhesive to the thin balsa making it hard to remove?? Tight edge seam will help here.
Mark
It will bond to the tape, but both sand away easily at about the same rate as balsa.
Vince
