ORIGINAL: jasonc1354
The pegasus is an option we have also since we have one sitting idle at the moment. Im not sure if it will fit in the bypass we have so we will have to check. As far as fuel tanks go are you guys running with just the two main tanks and UAT or do you have the third tank in use also?
There are three tanks plus the UAT. BVM sells the appropiate bypass and tailpipe for the AMT. Make sure you tell them that AMT is what you're powering that rhino with otherwise you will have problems with the pipe diameter being too small. I had that problem with my Cammo F-4.
