ORIGINAL: marwen1
I have need for a PLYWOOD that is LONGER than anything locally available.
Windsor Plywood (
http://www.windsorplywood.com/ ) lists baltic birch ply in 3 through 24mm in 60"x60" sheets. You could laminate the 3mm stuff to get whatever thickness ribs you need, and you could get a lot of ribs outta 3mmx60"x60" !! For seventeen bucks ? That's a steal, down heah.
Now, if the chord exceeds 60" . . .
<g>
