RE: will these two work together?
I have researched this motor, and there are two types that I am seeing posted in different sites. One at 27turns, and one at 23turns. There are more people saying the it is a standard mabuchi with an advance timing meaning its 27t. If this is correct, then the TEU-101BK would be fine.
If its 23t then you will need the TEU-302BK.
Personally I think its a 27t, its the super stocks that are 23t.
And Yes It will work with your radio receiver, just make sure you are using the correct rx plug from the esc, or just re-arrange the 3 wires to match the rx. red +, black -, white signal.
