RE: spinner question
1/4x28 is a very commom propeller shaft nut size and a wide variety of spinner sizes will work. It depends on what looks right on your plane. You can even leave the spinner off completely if you are flying something like a scale Piper Cub, which just looks wrong when it has a spinner. Just make sure that the no part of the prop blade makes contact with the spinner. Cut the blade openings bigger if you have to.
