RCU Forums - View Single Post - pull start tips
Old 07-06-2006 | 01:09 AM
hpi apollo's Avatar
hpi apollo
Default RE: pull start tips
if you use after run oil in the engine do about 3 pulls before priming to clear that out, do short quick pull of no more than 10 inches, and when priming, bring fuel just up to the carb, and then a little bit more, then start cranking, the most common problem is overpriming, and having a fully charged glow ignitor makes a world's difference too
