Well here we go with the other wing. I decided to make this plane a taildragger so it took some modifications to the location of the gear block and braces. I moved the gear hardwood blocks forward to butt against the spar and made up some ply supports to match the cutouts. I sure hope this works!! Sometimes I get myself in trouble by going off on tangents. I do believe it will work out OK but I don't necessarily recommend my "engineering" to anyone. I filled in the old cutouts as you can see and substituted some rock hard wood for the vertical torsional brace for the 5/32nd landing gear wire.
