RE: ABC Hobby Freedom RZ Outdrive unit?
The problem is going to lie in that the bushings in the lower unit are junk. Replacing them with bearings would help a lot. See if you can get some spare belts while you're at it as I can see where on the jackshaft going to the propshaft could easily pop off if you got some debris in there.
