RCU Forums - View Single Post - Running out of fuel on down lines.
Old 07-07-2006 | 11:31 PM
Cyberwolf's Avatar
Cyberwolf
Default RE: Running out of fuel on down lines.
Did you happened to check the clunk in the tank to see if the impact moved it to the front of the tank .The engine should run as good in a downline position as any other .Its sounds like a for sure out of fuel condition .check the clunk ,lines and watch the fuel line going to the carb for fuel .I have a twist and had to put the tank right up against the top to get anywhere near the center of tank position with the engine mounted upright .
What engine are you using, prop ,fuel & plug?
