RCU Forums - View Single Post - Transition from Foam??
Old 07-08-2006 | 12:02 PM
McFlyboy's Avatar
McFlyboy
Default RE: Transition from Foam??
ORIGINAL: AeroDave
Since the detatchable wing is key, you might also try the H9 twist. Nice and small, flies very well. I'm not sure if the 40 sized MOJO has a removable wing option.....???
you wouldn't have that problem with a Mojo, but you'd need to build it (not a problem). I just think you'd be more comfortable with a Twist banging around in your cap than a Mojo. Oh yeah, they cost like $99 bucks, too.
Yes, there is a version of the mojo kit now available with the removable wing. And there is also a ARF vers. too, dunno if that has split wings though
