Rounded wingtips on 4*60
Hi all!
I'm thinking of adding a thicker block of plywood to the wingtips, and then sanding the corners a bit.. to make the wingtips a bit rounded. I just don't them, flat, as they are originally.
My question is, since the tips will not be flat, is it going to be a problem to cover them later with Monokote?
On a stock version, you just put a piece on top of the flat tip... since this one will be rounded...how hard will it be to cover it nicely??
-eugn
