RCU Forums - View Single Post - Showtime
Thread: Showtime
Old 07-08-2006 | 07:31 PM
  #1710
Matt-in-the-hat's Avatar
Matt-in-the-hat
Default RE: Showtime
ORIGINAL: matt flyer
Hello I just ordered a S.T with a Saito 125 and Hitec 645's all around. I was just wondering if some one could summerise this thread for me cause Its 68 pages and im not about to read it lol . Just any bad habbits or any thing I should do or know before building or flying.
Thanks alot
Matt
ORIGINAL: BoneDoc
Reinforce firewall. That's about it. It has neutral handling, and with a 125 put the rudder servo in the fuse as pull pull.
I got mine last summer, over 40 flights on it so far. I made no modifications. Didn;t touch the firewall. I used a single servo mounted in the tail for the rudder.
I am using the TT120 2 stroke. I have experienced the issue where the plane does not leave the ground even at full throttle it hugs the ground. I compensate for that with about 20 degrees of flaprons on takeoff. and it takes off at 1/3rd throttle. other than that the plane is a Gem. flies really nice pattern.
