RE: Running out of fuel on down lines.
If the low speed needle is a bit on the rich side, especially if the idle is set on the slow side, you can get a dead stick situation very easily when the nose is pointed down for a few seconds without worrying about the fuel or clunk position in the tank.
Try simply checking low speed tuning and set the idle a bit higher and see if all does not go well.
Ernie
