RCU Forums - View Single Post - About cost and relative value
Old 07-09-2006 | 07:47 AM
James S.
Default RE: About cost and relative value
Tanker447 No problem I had posted it over on the [link=http://www.gusekweb.com/heat/forums/]H*E*A*T[/link] forum but mostly because of the 2150 mAh for Futaba transimitters (OEM are 600 mAh).
I bought 2 batteries plus that charger for ~60.00 on ebay only to later realize I did not need the charger my 977 would do the job. So I sold it to another club member and we tested it at the last Danville battleday worked well not fancy no indication about how much longer to go but it does beep at you so you do not have to keep checking on it.
As for the 2150's I used one for 3 days at Danville and it still was reading over 80% I did a discharge on it once I was home and it still had ~1200 mAh left which is twice the capacity of a standard futaba transmitter pack. [sm=thumbup.gif]
Regards,
James
