RE: Profile P-38 on FLOATS- HELP
Thanks for the input, Well, the picture is actually not just after nailing the throttle, but that is how it is running at high speed. Hence my confusion to not lift. Yes, the step is sharp foam and CG, per the advice here in the float forum is ON the step after building.
The water rudder is loaded down with a rubber band, so I would guess up at speed.
Thanks for the come back.
Twinman
