Hi Twinman, hope you get things worked out. If all else fails you might want to try shortening the floats as they look a bit long and are sticking out the front further than is usual. Some pics below that I had stored away. You can see from the chart that the recommended length for the floats is 75% of the fuse length. Note on the Spit how much closer the ends are to the nose. Couple of fanasty pics of a Sealighting also there that I thought you might like - don't copy those floats
